What the hey??? 84' Johnson Lower Unit
Xcusme
Johnson 1984 6HP J6RCRM- E6002165<br /><br />Can someone check 2 things for me please??<br /><br />My manual (OMC) shows a thrust washer (part 303361) towards the prop end of the reverse gear. My L/U doesn't have this washer. I can see slight wear on the face of the gear case head. Did OMC make any changes to omit this thrust washer?? It doesn't make any sense to me to have reverse gear riding on the aluminum gear case head. :eek: Perhaps someone had some left over parts after horsing around in this lower unit. :( <br /><br />Next question:<br />My reverse gear is 393850, the parts list shows 393939. Is this a part number change?? Supercede??<br /><br />Thanks in advance for any info.
Chinewalker
Re: What the hey??? 84' Johnson Lower Unit
Hi X,<br /> I just had one of these apart last night. There wasn't a thrust washer in mine, the gear does ride on the wavey looking surface of the rear carrier...<br />- Scott
Xcusme
Chine,<br /><br />Gees, this is strange...the manual clearly does show a thrust washer and the part number is a valid OMC part, and still available. My parts guy did confirm that the parts list shows the washer. Perhaps one of the OMC guru's can chime in with more info. Thanks for your info.
Xcusme
Bump
