What The Hell Did I Do Wrong ???
fuu
Besides hitting a rock and blowing out the lower unit.. I got a DT 25 hp 1977 Suzuki I have replace foward/reverse and the pinion gear and the clutch dog and some shift linkage ..I also bought a shop manual,, I put the whole package back together according to specs (I think) any ways I ran it for about 5 hrs and check the oil and found metal in it , So I took it apart again and found that all the bearings had lost all there crome ?????? the oil also had a slight burnt smell, the oil that I used was Valvoline lower unit oil, it can be used in all outboards .... does any know what could have gone wrong???? Is there a place that I could send the lower unit to , so that it could be rebuilt by some one that has done this before ?? thank you for any help.. Fly fisher
Hooty
Re: What The Hell Did I Do Wrong ???
ff,<br />A little metal "fuzz" in the lower unit is normal. It comes from the clutch, If you have larger pieces of metal and the bearings are discolored, you probably have something to tight. <br /><br />g'luck & c/6<br /><br />Hooty
