Okay, so I replaced the impeller, and theromastat, and temp guage on my 1989 4.3 mercruiser. I haven't replaced the temperature sensors.
Now when I run it at idle for about 10-15 minutes, the temp reads about 184 degrees, but will not drop it I give more throttle, neither will it rise. Is 184 degrees seem about right?? the t-stat is 140 degrees!! Any input would be appreciated!!
Also the Starboard side of the boat, the manifolds are super hot, while the port side is a just a little bit hot.
