So you are swapping out the 3 liter for the 4.3? I take it you already have the necessary fiberglass work, if any done.
The bolt heads for the exhaust pipe are unusual, but a 12 point 3/8 socket fits. If you want to take the bellhousing off you will either need the specialty tool or a 1/2" allen wrench.
I have my 4.3 engine and alhpa one gen II outdrive. What specialty tools will I need other than billows ring press and engine/drive shaft alignment tool?
Ayuh,.... Did ya get the drive for the 4.3l too,..??
You won't find a prop big enough to run a 1.98:1 drive behind a 4.3l,....
Ya want a 1.84:1 for hulls bigger than 'bout 20', 'n a 1.65:1 for lighter smaller hulls,.....
I built a jig to determine and build my motor mounts. Basically I would install the transom plate. Lay a piece of angle iron across the rear motor mounts on the transom plate. Have to remove the leather pads that the ears on the flywheel cover sit on. The forward motor mounts are within an 1/8th inch of 4 inches below that. And, the motor itself ALWAYS sits 13? down from the transom angle. As an example, if your transom is 73? vertical from the hull bottom (common transom angle) - that makes your transom 17? shy of 90? vertical from hull bottom. Your engine sits 17? minus 13? or 4? UP in relation to your hull. I believe the range can be anywhere +/- 5? to be in spec. So max transom angle is a range of 8? through 18? from vertical.
Anyway, I built a jig that makes building up your motor mounts really easy. The motor mounts height is exactly 3.5 inches below crankshaft center. From crankshaft center to top of transom motor mounts is roughly a 1/2 inch making the motor mount height ~4 inches below that. The other control is that height is set exactly 13? down from transom angle. My jig was a simple chunk of 3/4 ply. I used a c clamp to hold a 1.5 inch angle iron across the transom mount ears and slid the jig up underneath and held it against the transom. There's your height.
What is a billows ring press for?
Thank you! I appreciate your taking the time in being very helpful instead of telling me that I shouldn't own a boat unless I am a master marine mechanic with a full compliment of master marine mechanic tools and factory service manuals. I should be able to get it done using this though I may have a question or two when it comes down to it. Thanks so much !
Ayuh,.... I do just as explained in post #1,....
Mount the motor on the aft mounts, snug 'em down, 'n with a crane on the front of the motor, align it with the bar,....
Measure from there, pull the motor, 'n build up the front mounts,....
whatever the master marine mechanic name for it is, I don't know., but it's the disc made of a plastic tool used to press in the ring that holds the billows in place
personally I use power tune.
Do you need to buy the tool? No.
