What Spark Plugs should I be using on a 1981 Evinrude two cylinder 4hp.<br />Thanks in Advance.
A axscuba Cadet Joined Jun 14, 2005 Messages 17 Aug 31, 2005 #1 What Spark Plugs should I be using on a 1981 Evinrude two cylinder 4hp.<br />Thanks in Advance.
stan_deezy Lieutenant Commander Joined Oct 18, 2003 Messages 1,539 Sep 1, 2005 #2 Re: What Spark Plug Evinrude 4hp Champion L7J for 1981 model only<br /><br />1977-1980 it was L77J4<br /><br />and 1982-1987 it was RL86C<br /><br />hope it definitely is a 1981 model
A axscuba Cadet Joined Jun 14, 2005 Messages 17 Sep 1, 2005 #3 Re: What Spark Plug Evinrude 4hp The No. of the engine is E4BRCIC<br />Can you confirm if it is a 1981.<br />thanks
stan_deezy Lieutenant Commander Joined Oct 18, 2003 Messages 1,539 Sep 1, 2005 #4 Re: What Spark Plug Evinrude 4hp certainly appears to be that if you remove the final "C" from the number.<br />You can check it at this site: http://ww3.kencook.com/evinrudejohnsonmanuals/index.cfm?fuseaction=home.main <br />click on search in the top right hand corner.
