stumpwalker
- Sep 30, 2010
- 5
I have an old 15 foot tri-hull with a 50 HP Johnson circa 1971. There is not label anywhere to be found regarding weight and motor capacities. The motor has a compression issue that is not fixable. My question is what would be the smallest and largest horse power rating that can be used on this boat? I am not really concerned about speed since this boat is used primarly for fishing and the larger the motor the larger the cost. I go from point A to point B fishing spot but do a lot of fishing on Seneca Lake in NY which is a large rough lake. The only concern I have by going to a smaller HP is as it relates to the weight of the boat and stuff that I bring. Gotta pack sandwiches and cold drinks plus I alone weigh 250lbs.
