What size kicker?
namegos
Our 26 foot 1979 SeaRay Sundancer is propelled by a single screw 260 MerCruiser I/O.
To safely fish Isle Royale (Lake Superior) this boat needs a kicker (get back) motor.
Hoping to hear some advice from anybody who's successfully added a motor/bracket/control system to a boat of this size and weight.
ondarvr
For a boat that size and on water like that, you'll need something in the 20+HP (high thrust model) range to really make it move in bad weather. If you were on different waters you could get by with a smaller motor.
​26' footers here use 9.9 and 15HP kickers for fishing, but if your goal is to get you back in nasty weather the larger motor will work better
Going out in Lake Superior to Isle Royal, i would want twins. However as ondarvr stated, a good bracket and a 20hp
Lake Superior doesnt give up its dead
Have EPIRBs, a dinghy and a good radio
fishin98
A good solid mount and a 15hp properly propped will do the trick.
