What size block is this
llerrad
Have 1972 Merc 188 I/O was wondering is this a Ford 289 or 302? and what is the best ignition conversion kit to use (going from points to electronic)
JasonB
Re: What size block is this
I have the same engine (1976) and plan on installing a Pertronix Ignitor II from vintageperformance.com to replace the points in mine. I will also be replacing the original 1976 coil with a new Flamethrower 35-40k volt marine coil. There are two pertronix kits for this engine. The standard Ignitor and the Ignitor II. They do the same job (I is about $70 and II is $100) but the II has an automatic shutoff feature if you leave the key onn with teh engine off. It also auto adjusts dwell to some extent. You can look it us as a Mercruiser 888. I believe the kit Trent pointed you to is the standard Ignitor or its equivelant.<br /><br />Just to echo Trent, it is a 302. Good engine :)
Capt Ken
OK, yes and no. It is a 302 block with 351 heads and 351 cam. Because of the cam, the firing order is different than a run of the mill 302.
JasonB
Be careful when getting engine parts. My 888 had been replaced with an engine using 302 heads.
