Re: What should the compression be for a 1989 60HP Johnson?
Ahoy, Sandman. All cylinders should be within 5-10# of each other and over 100#, cold.<br /><br />If the engine is where you can test it under load, do so. If not, test it in a tank or on a hose. Pull each plug wire, in turn, and see that each causes a drop in rpm and can arc at least 1/2" to the block. Be sure that it provides a strong, warm telltale stream after warm-up. Inspect the plugs after the test. They should be gray or tan, and dry.<br /><br />Gearcase oil should not be milky. If you remove the fill plug with the vent plug in, you should not get water out.<br /><br />If you buy it, be sure you "prop it out", so that over-propping doesn't shorten its life.<br /><br />I'm sure others can add to this.<br /><br />Red sky at night. . . <br />JB
