The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
I HAVE TWO 150HP JOHNSON OCEAN RUNNERS MODEL HJ150NXEOM SERIAL NO GO3793333 I HAVE A 4 BLADE 15 INCH PROPS ON . AT WIDE OPEN THROTTLE WHAT SHOULD MY REVS BE?
your revs should be around 5500 to 6000 RPM. If you aren't around this RPM, then you may need to try a different set of props, or look at the way the motors are setup on the boat.<br /><br />P.S. turn off your Caps Lock, it's considered shouting to write a whole message in capital letters
