Re: What should be replaced when replacing pistons?
Again, you say you mean no disrespect, then go right in to being disrespectful. You are assuming I am not competent by saying things like, "training", and "you don't understand or have the knowledge". I have laid out my steps, I have followed advice. Everyone has been very helpful. Some people are not cut out to be teachers, I am not blaming you. You are just not being very patient or forgiving. If it frustrates you, then just don't post. I was getting a lot of information from others. It seem like you just chimed in because you wanted to rant. Sometimes it is best to leave things unsaid. I won't be offended at all if you choose not to help. I understand. Thanks
John
To the others, what I was originally asking in this thread was, do I need to have the head or the powerhead casing machined, as in surfaced, like you would an automobile engine? I know it has to be bored to put oversized pistons in, that wasn't even a question. I guess what I meant to say was, what other things should be replaced when boring and installing oversized pistons/rings. Like, do I have to put certain bearings in or wrist pins? Are there dowels that should be replaced, you know, things that go unnoticed? Sorry if it got confusing. Are there any special tools needed? I have every hand tools( ring compressor, hone-for cross hatching) and most specialty tools out there, so I should be ok, unless there is something you can think of.
