What Shop Manual for 93 Volvo 230a/SP?
LBJ
I have a cooling system problem and want to do the repair myself.
There is a chirping sound coming from the engine after it warms up to about 150 degrees. (The guage is probably off 10 degrees or so.) The engine then goes on to overheat. I recently changed the belt and heat exchanger cap.
I would appreciate knowledge of a good source for the manual and parts but please I need advice too.
Are there bearings in the water pump? Can the impeller make noise when worn out? Is the problem somewhere else?
