What re the correct plugs for a 2000 90HP Johnson ocean pro ?
weekendfisher
Hey,
I am trying to find the correct type of plugs to use in a 90HP johnson 4cyl looper.
The plugs in it now are NGK BR7HS 10 which i do not think are the correct ones.
The model of the motor is J90VLSSS
Also the warm up idle lever seems to really only have one setting when you lift it nothing happens uptil it is all the way up and then the linkages move but it is more like a pre set amount there is no adjustment so you can't actually adjust the idle RPM it is either on or off as such .. is this correct for this type motor ? on my 50 the lever brings the idle up as i lift it but on the 90 its more like a switch as the lever hits the top.
Thanks
Barnacle_Bill
Re: What re the correct plugs for a 2000 90HP Johnson ocean pro ?
NGK site calls for BPZ8HS-10
boobie
QL78YC Champion. Your throttle cable may be out of adjustment on the mtr causing your warm up lever not to work properly.
