Re: What prop size for Yamaha 150 on Wahoo 21 CC?
I've got a 150 Merc. on a 20' Grady and I'm currently spinning a 14 x 17 SS. The most important thing is to prop it so the motor can reach the upper end of it's WOT rpm range (probably 5000 to 5500) when the boat is loaded with the no. of persons, fuel, gear, etc. that you will normally run it with. My prop let me spin up to 5800 which is a little too much so I'll probably be dropping back to to a 14 x 19. I believe Merc. props will fit Yamaha motors. Merc. has a prop demo program where they will let you try various props before buying one. You might want to contact your local Merc. dealer for info.<br /><br />Good luck.<br /><br />Brian
