What prop should I switch to
allenc28
I have a 19' 92 Bayliner capri with an I/O merc 3.0 and alpha 1, I think it has 135hp maybe I use it mainly for water sports like tubing and wakeboarding but do fish every once in a while. I have an aluminum 14x19 on there now but it takes forever to plane and pull me so I want to switch to a 4 prop but don't know what size to get can I please get some help. I cant remember what my rpms generally run. thanx ac
Re: need a new prop please help
Ayuh,... Welcome Aboard,...
Please read the "Read this First" thread, so you can provide the Necessary Info...
allenc28
sorry i just realized that i put the rest of the info that i know into my first post im new to all this
Ayuh,... Without Rpms, at Wot, there just ain't no way to answer yer question...
allenc28
my current prop is so chewed up will it give me an acurrate rmp @ wot or should i just guess and buy a prop? my dad gave me the boat so thats why i dont know much about it
Ayuh,... With the total lack of Info, 'n based on this tiny tidbit,...
I'd guess you could Try a 4 blade 18" pitch prop....
allenc28
Thank you so much I will so that and take it out this weekend and get my rpm info and see how it works
allenc28
ok took the boat out this weekend and got the specs wot is right at 5000 and like i said my prop is pretty bad off i ran it just long enough to get the wot so with that i hope someone can help to let me know which pitch to get with a 4 blade prop and possibly what a good brand is that wont break the bank
steelespike
You can probably get the prop fixed and get some real numbers then if a change is in order you can keep the prop for a spare.
steelespike
The Solas Amita won't break the bank and we have had a lot of good reports on them.
You might first want to be sure the motor is in excellent tune,good compressioon and the throttle opens all the way.Someytimes the foam under the floor absorbs water and can add a couple of hundred pounds right at the stern where it hurts most.
Mordekai
I just went from a 21p 14.25 blade to a solas rubex 4 blade of the same pitch and gained 3 mph throughout the entire engine range. This is also on a 3.0L but my engine is 2010. Ditto with others with making sure your engine is shipshape first.
Joshua Nichols
I didn't realize he was going to run a aluminum.. Yep those are cheap...
Tail_Gunner
That would be both a great guess and selection..Solas amita 4 blade 18..or 19
