What product to use to tack glue o ring on to waterpump housing?
ctswf
Hi, I have done this once before a few years back but need a little memory refreshing. Motor is 1982 70hp evinrude. I have purchased a waterpump kit w housing, what can I use to glue the large o ring "gasket" to the housing so it doesnt fall off as I slide the housing down the shaft? Waterpump kit is Part 18-3389 Thank you
rothfm
Ensign
I use 3M black weatherstrip adhesive. Dries good to hold it in place, stays flexible so it will compress as it should
A bit messy but works great
HighTrim
3M 847 is ideal if you have it. Same as used to reseal gearcases.
F_R
If you are only concerned with sticking the oring in the housing, it really doesn't much matter. Whatever sticky goo you have on hand will do.
F_R
Me too. But not enough to go out and buy some for just that one use.
ctswf
Thanks everyone.
How about permilux super high tack? I have that, It says used to hold gaskets in place while assembling.
...not sure if its non hardning.
I also have a non hardling gasket sealer I think I used last time but it doesnt dry fast or tacky so its harder to keep the gasket in place
ctswf
Well I used tiny drops of the high tack and shes spitting water solid so I suppose it worked
