Jim Robbins
- Jun 15, 2005
- 85
I have a 140 HP Mercruiser (ser.# 3129102 (1971 or 1972 ?) and the old manual said to use a
SAE 30 / API Class. MS or SD *what does the MS or SD mean?
I should use a SAE 30 weight oil that is a Nondetergent type - correct?
(I boat in Lake Huron (fresh water)
When changing the oil, have cooling water flowing through wp, start up the engine
(do I use an engine flush to help loosen up any sluge OR drain oper. temp. oil then add fresh oil, start up to temp. and drain again ?)
run engine up to opperating temp, drain oil.
Change oil filter (coat of oil around sealing ring, tighten securely by hand) fill crankcase with proper amount of oil, run engine a few mins. check for oil leaks, shut down wait a few mins and check dip stick (add more oil if needed). Anything I missed or any advice?
