What oil do you use in your Yamaha 2-stroke
I was just at a local tournament and guys were talking about a AMS-OIL semi synthetic that they were running in their Mercs, I have a 99 Yamy Vmax 150 and she likes to smoke a little on start up, is anyone using anything but the Yamaha oil?
JB
Re: What oil do you use in your Yamaha 2-stroke
Any TC-W3 oil is appropriate for your outboard. AMSOIL is infamous for bogus claims. NOT recommended here.
I just recently bought two gallons of Pennzoil XLF that I'm switching over to as soon as my oil tank is empty. I run a Yamaha 225. I asked a lot of questions and did a lot of research before deciding to make the switch. It's a lot cheaper ($14.00) a gallon at WalMart and is a TC-W3 oil. I ran the really cheap WalMart brand 2 stroke oil in a brand new 200 HP Mercury I had on my first boat and never had a single problem with it.
Bamaman1
I've run WalMart outboard motor oil in a 1990 SeaDoo PWC and a 1985 Yamaha 115 hp 2 stroke motor, and they both continue to run great. The last time I cleaned the head on the SeaDoo, it was completely clean (without carbon.) As long as the oil meets the industry standards, I'll keep on using it.
If I ever went to an Optimax or other modern injected 2 stroke outboard, I would use the factory oil as long as it was in factory warranty. I assume some of these use semi-synthetic's and/or full synthetics. Then, I would probably switch to one of the big name oils--Pennzoil, etc. Luckily, WalMart also sells most brands of premium and factory oils at prices much lower than boat dealerships.
I'm running a Yamaha FX Cruiser PWC this year, and I found that WalMart also sells Yamaha outboard oil filters that also fit their PWC's. My local motorcycle/PWC dealership charges 150% of list price, and they wanted a small fortune for a filter. I'm running motorcycle oil in its dry sump--pretty expensive stuff.
Whenever the Yamie 115 gives up the ghost, we plan on replacing it with a modern 4 stroke and a new pontoon boat. I just wonder how long it'll run?
hey quick question, i have the same yamaha motor on my boat, and i was wondering if you still put oil in the gas since its a 2 stroke, or do u just add it to the tank on the motor itself? this is my first time with a motor over 25 hp, so im just wanting to make sure i dont screw anything up.
MaineFishin
The oil is added one way or the other, not both unless you are in the engine break in period.
boater1234
Master Chief Petty Officer
100% tcw3 full synthetic pennzoil.The best oil i have used as far as way less smoke and seems to burn cleaner+biodegradable.Any oil will work though.I have used the walmart brand forever till i switched over to the full synthetic and i will never go back to reg oil.Not that it's bad i just like the way it runs cleaner and idles way better,plus way less smoke if almost any at all.
harvey5560
I was advised by my mechanic to use the Mercury or Evinrude xd-50 and NOT the Yamalube due to excessive carbon build up with Yamalube. I was sceptible so I researched it quite a bit on the internet and lots of people seem to be reporting excessive carbon buildup.
robert graham
100% tcw3 full synthetic pennzoil.The best oil i have used as far as way less smoke and seems to burn cleaner+biodegradable.Any oil will work though.I have used the walmart brand forever till i switched over to the full synthetic and i will never go back o reg oil.Not that it's bad i just like the way it runs cleaner and idles way better,plus way less smoke if almost any at all.
My 2nd on what boater 1234 says about the Pennzoil 100% Synthetic, costs more but less smoke, carbon. Good Luck!
