Re: What octane gasoline
Hi Mike,<br /> Do NOT run your motor at 50:1 ratio. It has bronze bushings at the wrist pins and needs the extra oil to keep them lubed. It also has a bronze bushing under the center main bearing which acts as a compression seal between the top and bottom crankcase cavities. The oil acts as a sealant on the bushing, preventing blow-by. The tolerances in these old motors are much looser than new motors, so the oil does more than just lubricate the parts - it also helps keep things tight. 32:1 is as lean as I would go on the oil.<br />- Scott
