What Motor Size?
ZeroJunk
What would be a good motor size to put on a 13 foot 7 inch Glasspar G3.I don't need to win any races ,but I want it to come on plane easily and run 40 MPH or so.
JB
Re: What Motor Size?
First: what is the boat rated for, Zero?
Generally, satisfactory performance from most hull types can be found with at least 70% of the rated max HP. 100% of rated max hp would get you maybe 2-3 more mph.
Exceeding the rated max HP can be dangerous.
Forty mph in a 13'-14' boat is very fast. I have been there in a Boston Whaler 13' and chine walking is a possibility. That is scary.
ZeroJunk
This boat was made in 1960 and I am rebuilding the transom and stringers.There is no indication on the boat about horsepower rating.Hoping somebody may have worked with a G3 or similar boat.
tashasdaddy
there is a Coast Guard formula, for rating the HP, for those boats. deal with length, width, tiller control, or remote control, transom height. if yu can post a picture or 3, and the dimensions, i will try to locate the formula.
ZeroJunk
Here is a picture to give an adea of the type of boat.Transom height is approx. 16 inches-designed for a short shaft.So,I plan on using a jack plate.Oh,well.Doesn't like my picture.
Frank Acampora
I believe the G3 was built for modest HP --about 40. The 15 inch transom was a reason for the low rating. I was a young motorhead when the G3 was built (late '50s - early '60s if I remember correctly) so back then I knew all the specs-- now, memory is not so sure.
The jackplate is good, but as long as you are rebuilding the transom, I personally would build it up 5 inches to avoid the extra weight of the jackplate.
With proper transom reinforcement I think she could handle a 60-65 HP. After all, she was designed to be a cute, quick boat.
As a comparison, I have an old 14 foot flat bottom that looks similar to the G3. With 65 HP it goes 45 and with 90 HP it goes 55 plus.
Stern weight will be an issue with this boat: remember, you are sitting near the stern and a 60 HP with power trim will weigh a bit. Remember: you have a light, stern heavy boat with a fairly wide, flat bow. Bow lift at higher speeds may become an issue. for the first few runs and until you get comfortable with her handling, build up your speed slowly and be alert for instability. With this boat, I would constantly wear my PFD, and a functioning deadman engine kill switch is a MUST.
But she is a sweet looking hull and a great Sunday ride. Good luck with her.
ZeroJunk
Sorry about this.I am still trying to figure out the photo deal .I have always just downloaded jpegs directly to a forum which I can't do here.I know photobucket etc.works better.I'll get into it later.
