Re: what might be causing my Yamaha GPR1200 exhaust temp warning light to come o
have it checked ,I had a friend who burned up a rear piston in a yamaha TWICE because a baffel came loose in the muffler and obstructed the exhaust , it may just be a clogged water passage or even a bad sender but don't ignore it because the end result will be a burned piston if the exhaust gets too hot , you may feel around when you drive it and see if it is actually running hot.
