Re: What makes a Stator go bad? and once i replace it will this happen again?
A
properly designed and
properly built stator should last forever. To understand why some stators don't last forever, look at some of the things contributing to a
properly built stator. Important things are that the stator design uses wire large enough to carry the intended current, has insulation able to withstand expected voltages, and that the wire insulation be able to stand the heat from both the amps passing through it and from the engine in any environment. The stator must be built without damage to the wire insulation, tightly wound so that the windings do not become loose and suffer mechanical damage, with magnetic steel that does not create hot spots, and good quality connections must be made.<br /><br />So, mechanical damage will cause a stator to fail. The very high heat caused by prolonged excessive amps will cause near term failure. A short circuit may melt both the insulation and the wires. A high voltage spike may cause insulation failure.<br /><br />
Michael O - Buy a replacement from a reputable manufacturer and you should get a
properly built stator. Make sure the replacement is rated for the expected amp load. Make sure when you install it that nothing will hit it when the engine is running. Make sure that your rectifier is working properly and has no shorted diodes so as not to overload the stator. Check to make sure there are no blown fuses indicating a shorted load. Make sure the stator is connected to your battery whenever the engine is running. And if you have a regulator and rotating field winding, make sure it's working properly. Then you should be good to go.
