Lil Kicker
- Jul 19, 2023
- 6
Took it to my local box store and the Merc fitting does not fit. None of them did?Hard to argue with that...
Not unless it’s some kind of old system. Took it to my local box store and no fitting including Merc would not fit?Well the tank says it's quicksilver. So I amguessing it is a Mercury fitting.
Thanks I’ll have a lookMerc makes that fitting. There are 2 different ones. Outside shot it's a Yamaha
That’s is the same fitting on my gas tank, thank you. I purchased a 14’ boat and it came with it. But no motor.Did that tank come with an engine that you know of?
If yes, what engine serial number and HP size?
What size gas tank is it?
I believe your tank is like this one of part number 1265-859065A3, https://www.2040-parts.com/mercury-quicksilver-6-6-gal-marine-boat-fuel-gas-tank-w-gauge-i1133639/
Which is kind of leading to item number 10 but not 100% sure on that, https://www.mercruiserparts.com/bam/subassembly/32050/11844/58
All in which could be hiding somewhere in here, https://www.mercruiserparts.com/fuel-oil-tanks-lines-filter-kits-and-c-1
Or in here under where used, https://www.mercruiserparts.com/859065a3-tank-fuel-6-6-gal
But maybe knowing what engine might help some.
