Re: what lower unit oil?
you were told correct. you should use a lighter blend which is available from dealers and i believe wal-mart carries it also.Not sure of weight off the top of my head.The heavier oil can cause some expensive problems with the hyd pump.<br /><br /><br />------------------<br />no replacement for displacement!
