What kind of trim pump oil to use
scott8058
Ok so last week i found that i was getting water in my gear oil and trim pump oil. We are tearing the outdrive off to replace the gaskets and seals but my question is what kind of oil do i put in trim pump? The oil is a thick creamy yellowish color is why im assuming there is water getting in but idk what color its supposed to be.
Thanks
Oh yeah just in case it matters......5.7l i/o w alpha one
Don S
Re: What kind of trim pump oil to use
10 w 30 motor oil.
scott8058
really so thats just regular old motor oil in that little tank on it?
ktbarrentine
Yeah... you can spend the big bucks on the mercruiser power trim fluid, but 10w30 works just fine.... Now, if it is actually water contaminated, you need to figure out why and fix that.
