what kind is it
broke angler
I have an older trolling motor with no markings on it. It is 12/24 volt with a rectangle head and a glass top to see the directional arrow(which has been modified by the way). The prop is held on with a shaft pin and carter key. Can someone help thanks.
sorry see if these help
Silvertip
Re: what kind is it
Not a chance with the little iinformation you provided. How about some pictures.
STARCRAFT16SS
Re: what kind is it
Hello....I have one that looks somewhat like yours but is an off white
color....look at your foot control....look under the foot/rocker pedal...
should be some numbers there.....
STARCRAFT16SS
Re: what kind is it
Hmmmm....looking at the pics...Broke Angler....it looks like you are missing
the disc that indicates which way your trolling motor is pointed...take a look
at the top of my trolling motor...also mine is only a 12 volt....and the clear lens has been replaced with pexi-glass disc held on with 6 brass screws
