Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
Today I mounted a 2003 Johnson 90 hp on a 1985 Bayliner. I did a bit of research and decided to mount the motor so that the cavitation plate was 1 inch higher than the bottom of the hull. When the motor was hanging from the hoist and marking the holes to drill, something did not seem right.
This is how it ended up. The cavitation plate is almost 1 inch higher, but not along its full length. I think when the motor is trimmed out a little to its normal running trim, it will be 1 full inch higher.
But look what the top of the tranom looks like!!! There is two full inches of space between the transom cap the the bottom of the transom mounts!
So I pull out the service manual and check, the 90 hp only came in 20" modles in 2002-2003. This measures 22 inches from top of transom mount to cavatation plate. That would be a "special" according to BRP, but no special 22.5" models were made those years. So this is a 20"?
I checked the model number, and it was obliterated by the idiot who did the prep for the paint job (its not stamped, it is a sticker!). But knowing that there were only 20" models made in the V4 configuration, I'm guessing this is the normal mid section for this motor.
If I lowered the motor to have the cavitation plate even with the bottom of the hull, it would only be 1 inch higher than the transom cap.
When I drilled the holes, I made sure that the motor can be lowered on the transom bracket if I want to.
I'm going to test it like this, but I am surprised it sits so high above the transom.
BTW, the transom measures 19.5" height.
Any comments?
Any comments?
