what is this?!
Vic.S
Re: what is this?!
Whats the top layer? gasoline?
If so its not diesel in the bottom as that would mix with the gas.
Very likely something water based.
confirm that by shaking a little with some water.
Antifreeze?
Not sure (ougt to be!) if brake fluid is miscible with gasoline.
Joe Reeves
Re: what is this?!
Separate the two substances, then go to the smell test. That should tell you something.
Vic.S
Re: what is this?!
probably find that every thing smells of gasoline unless the contaminant is itself has very powerful odour. Then everything will smell of it!
