What is this reservoir for? Coolant? Where does the line run to?
xboat
Hello peoples! I’m new to boating and I got this boat for free. However I can’t seem to find what this bottle is for or where it was connected. It is currently disconnected and don’t know what it was filled with.
I’m assuming it is for coolant but I’m not sure. Please help or link any diagrams, if any…
Photos here
tpenfield
It would be best to post a picture in this thread. (use the 'Attach Files' button). I did not see an image over on Reddit.
Free boats can be very expensive. It is hard to say what that line/tube is without seeing it. Sound like drive lube reservoir though . . . :unsure:
Photos here
Ayuh,....... Welcome Aboard,...... That's for gear oil, for the outdrive,.....
Grub54891
Be sure the line is still attached to the bottom of the resivoir and to the drive. It’s possible that someone replaced the drive and it doesn’t need it anymore. Or you have a leaky drive, or it wasn’t filled properly before. Seeing it’s a new to you boat, you should do the drive service and remove it for a good alignment and service. We can walk you through it. Check out the stickies at the top of the forums here and study them up.
nola mike
Looking at the reddit thread OP says it's been sitting exposed under a tree for 14 years. Gear lube is going to be the least of his worries
