Hi,<br /><br />This question concerns a 1988 Mercury Black Max V6, 150HP.<br /><br />The symptoms indicating a problem were, at first, a lack of power, taking a long time to plane (which it really shouldn't with this prop and HP) and not exceeding 4000 RPM, even with a smaller pitch prop (roughly same RPM is reached). The tachometer goes berserk above 2000 RPM, either dropping off to less than a thousand, or jumping wildly between 500-2500 RPM. Lastly, the engine doesn't sound right when this happens indicating something is wrong.<br /><br />Further testing at the dock shows that when in idle, and the engine is cold, for a brief moment it will idle above 2000 RPM and all seems well. However, as soon as the engine heats up a little bit the tacho stops working properly and the engine starts to sound rougher above that RPM. Note that a strobe does show spark on every cilinder (compression is also good), and as soon as the throttle is released just a bit to below 2000 RPM the tacho returns to normal and so does the engine.<br /><br />Tracing the tacho wire leads to a small black box, attached on top of the engine between the 2 top cylinders and the flywheel (near a water hose coming out of the block), attached with 2 bolts and having a red and a yellow wire, the metal body providing also a ground to the box. One of the wires goes to a connection point that includes the tacho wire (meaning the tacho wire going to the controls) and a connection leading to the stator, the other one goes to a connection point involving the switchboxes and also to the stator. <br /><br />When using a scope to look at the "input" wire, i.e. coming from stator, and before leading out of the part to the tacho, you can see a good pulsetrain, for this engine I believe it is 6 pulses per revolution. This pulse train stays perfect even above 2000 RPM when the engine starts to act up. If the tacho is connected to this point, rather than the "ouput" of this box, it works perfectly at every RPM. <br /><br />On the other wire though, the pulsetrain will break up above 2000 RPM (except not usually when engine is really cold, which doesn't last long), and the tacho will behave badly. The engine will also suddenly break up, sound changes. There is still spark on all cylinders, but I can't tell if for example it's only sparking every second revolution. If you take the scope probe and touch the other end, all is fine.<br /><br />The box itself measures as a direct connection between 2 wires (yellow and red). The scope can not identify it, there is no resistance either way. Still, it appears to do something because the input pulse train is badly butchered above 2000 RPM and the engine suffers suddenly (suddenly enough to suspect an ignition problem rather than a fuel problem - also because of the tach signal being butchered as well).<br /><br />My question is, what does this box do (filter?) and how to test if it is working correctly. Also if it is faulty can it cause my ignition problems? The engine always starts turn-key, probably because all is fine under 2000 RPM. I can just not imagine anything being designed to butcher a pulse train (cutting pulses) above a certain RPM.<br /><br />Sorry for the long post, but I thought I'd include as many details as possible. I wish I had brought a digital camera, a picture is worth a thousand words
<br /><br />Best regards,<br />Dennis
