HI Yall. 1988 125 #1251x8c,running well. On the left bottom of the exhaust manifold is a smooth bore hole about 5/8 dia. right below that is a 5/8 pipe plug, what am I looking at.? I have a black thermoswitch held into the head by a snapring, my manual says it should be changed to a red one,can not find one anywhere. I have no thermostat, dealer says I do not need one in FL. Gulf h2o temp is 86 degrees. TIP, I cut two pieces of foam rubber to fit around powerhead and leg, put it in when working on motor, droped screws, ect, wont fall dowm the leg.Big THANKS to all who reply.
