I have a 2005 125 merc 2 stroke. The previous owner just had a powerhead put on. It started to idle way slow and stall when put in gear. There is a black bar on the port side of the motor. On it is a screw with a plastic knob labelled idle speed adj. below that, and the only thing on same bar, is a bolt with a lock nut and a plastic tip on other end. This had vibrated loose and was not locked. Anybody know what this is or is called? It looks like a throttle stop?
