Re: What is the pitch and diameter of this prop?
I checked on the forums here and found that my motor should be running at a max recommended RPM of 5800. It only runs 4400, but it seems to me that there is not enough travel in the throttle arm. Motor doesn't seem to be laboring and the hole shot is pretty darned good. Boats I've owned in the past have had about 30 degrees more travel that this controller allows. Is there a limiting device that I may not be aware that the previous owner might have used? There is a knob that is on the controller that is just below the ignition key that I have no idea what it is for. I turned it, but didn't notice anything different going on.
