What is the difference in plugs
insearch
My Johnson has QL82C but I found a reference that suggests QL77JC4
I did find that both plugs are recommended for my motor, is there an advantage to having one or the other?
Kamdyn
Re: What is the difference in plugs
One plug is hotter than the other, The lower the number the hotter the plug is.
Vic.S
If two or more plugs are in the current recommended list you can use either. The first one listed will be the preferred one though if there is any preference.
With Champion plugs the higher number is hotter than a lower number
( with NGK plugs and Denso plugs the lower number is hotter. Dont know about other makes without looking it up)
Look up the latest recommendations HERE
EDIT
Just read elsewhere on the forum that someone prefers the QL82C for trolling because its just that little bit hotter. You may want to experiment to discover which suits your needs better
