As title says, how does one measure if one has short, long or extra long shaft.
I am trying to adjust shift rod length on 88 140 lopper.
I have a 1988 full johnson workshop repair manual
at the beginning in specs it gives shift 2 rod lengths only for the 140 HP , but towards the section on gear boxes and shift rod length it gives 3 lengths, for the 140hp V4 short, long and extra long .
I had trouble recently because of rod adjustment and it was always too short press the rod down into reverse, I figured that the rod must be set too short . Now with this repair manual, I figure that the middle measurement given in the 2nd box is long shaft and that is why I am missing the downward travel of the shift rod.
Is it measured by the drive shaft length or length of lower unit or transom to ????
thanks guys
thanks guys
