What is the correct oil to use?
urcowboy
I have a '72 Evinrude w/ hydraulic shift and have been told that I should not run the standard lower unit oil, but something thinner to keep from having shifting problems. Is there any truth to this? What weight should I use? Help!
wvmarine
Re: What is the correct oil to use?
If it electric shift, use only premium type C gear lube. Lubrimatic makes it.
