I am in the market to buy the upper unit for my alpha one outdrive. The upper unit is stamped 1.53 (Ithink it's a 3) which I believe is geared for a 8 cylinder. I was trying to find info on the web about what the proper gear ratio should be for a 1986 Mercruiser 3.7L 4 cylinder but not having much luck. Does anybody know where I can find this info? A family member has one that is a 1.98 that came off a 4 cylinder, some else tells me that I should put a 1.84? ratio on it. Any suggestions?
