What is the best oil for 1994 90HP 2 stroke Force?
tiras_usa
Hello folks,<br /><br />Couple month ago I purchased my first boat: 1994 Trophy 1802 WA with 90HP Force.<br />And I have couple questions:<br /><br />1. What is the best oil for 1994 90HP 2 stroke Force?<br />2. How often should I use decarb cleaner and what cleaner is the best one?<br />3. What is the recommended RPM (MAX, Cruse) for this engine (engine has been rebuild recently)?<br />4. What kind or brand spark plugs should I use?<br /><br />Thanks in advance,<br /><br />Alex_A
WillyBWright
Re: What is the best oil for 1994 90HP 2 stroke Force?
1. A better oil than they were using prior to the overhaul.<br />2. More often and better brand than the one they were using prior to the overhaul.<br />3. Fewer RPMs than they were running prior to the overhaul.<br />4. A brand different than the one it had prior to the overhaul.<br /><br /> ;) Bus Seriously Folks... ;) <br /><br />1. Merc's 2-stroke oils are good.<br />2. Merc's Power Tune is good.<br />3. Prop it to run at 5500 RPMs with an average load, then run it at 3/4 throttle.<br />4. Champion or NGK. Flip a coin.
phatmanmike
any oil that is tcw-3 certified will be fine.<br /><br />you should decarb once a year<br /><br />i dont know rpm, probably around 5500<br /><br />go to sparkplug.com to find out
tiras_usa
THANKS<br /> <br />º¤ø,¸¸,ø¤º° >(((((*> °º¤ø,¸¸,ø¤º°°
JB
Moving to FORCE troubles.
