Re: What is recommended prop for 96 Evinrude 90HP
columne,The correct prop selection for your engine and boat is the one that will allow the engine to attain the recommended wide open throttle rpm range.On your engine that is somewhere between 5500-5800 rpm.Not knowing the weight of your boat rigged out ,I'd guess between a 15" and a 17" pitch prop.As propped ,I don't recommend reving higher than 6000.
