Re: What is my gear ratio ?
My boat weighs 4,000# dry.
I just wish there was a stamp on it. The drive I'm looking to replace it with is not on a boat. It just an outdrive sitting on a stand. But If I turn the input shaft by hand, the prop shaft should turn the 1.5 times.
Being it is on stand, might be better to pull cap and count teeth.
Rotating the drive shaft, dealing with the grease and u-joints, holding the shift lever engaged, and counting prop shaft turns, could be a bit "fun" by oneself. With two people, one turning the input shaft while the other is holding shift lever and observing/counting prop turns, would be allot easier.
As mentioned already, you have the rotation count reversed.
What letter is stamped on input shaft?
Assuming your current set-up produced the correct wot rpms, what prop and pitch were you using?
