Re: What is a safe speed for tubing and/or skiing?
Based on doing it a lot of years, (Possibly all wrong), we pretty much use the following guidelines.
1.
Whatever speed the skier or tuber is comfortable with. That varies from idle for the very young first time tuber to 30-35 for some of the hot dog skiers.
2. Tubing is usually in the 18 to 25 range for the experienced tubers that want to have a wild ride. Probably 90% of the time a speed of 20 to 22 mph seems to be where we run.
Keep in mind that the tube speed is much higher when the tube has been "whipped" outside of the wake.
3. Most of the skiers that are on two skis seem to be most happy in the 20 to 25 area. Heavier skiers seem to need a little more speed to keep the skis on top of the water.
4. Most of the slalom skiers we pull usually want to go about 25 to 30. It pretty much depends on the skill level.
5. I usually use about 20 for my starting point and then let the skier/tuber vary my speed with their hand signals.
6. You will quickly learn that turns, especially tighter turns, will cause the boat to slow down considerably. You will soon learn to compensate for that.
One thing I do that may be a little odd to some is to just tap the throttle control with the heel of my hand when I want to vary my speed by only a small amount. I seem to be able to move it in very small increments by doing that.
One other thing. I have no idea how accurate speedometers are, (other than on tournament ski boats), so your speeds could be much different than mine. As a point of reference our runabout falls off plane about 15 mph indicated speed.
FWIW, when you see the grins on the kids faces, keep in mind that yours is probably even wider.
