What is a OMC tracker ?
tcan
I have a display on the instrument panel .. digital readout.. It shows a anchor and what appears to be a hull. Does anyone know how this works or what it is?:redface: Thanks.
Silvertip
Re: What is a OMC tracker ?
I guess if whatever number is being displayed happens to correspond to the approximate water depth it would be a depth finder. If that's the case, there will be transducer mounted on the transom or it may be a "shoot through hull" type and would be mounted somewhere inside the boat, under the floor, adjacent to the keel.
tcan
Thanks there is a little black box mounted on the transom. Now that I know what it's for I can figure out how to use it. THANKS AGAIN
