Got my 4.3 OMC Mark Twain out this summer to find it would not rev over 2800 RPM. So after reading several of the forums here. I rebuilt the carborator, put in new points, condensor and rotor. Changed the inline filter at the carb intake. Replaced the fuel seperator with a new one. All of this realy help the idle but it is still missing or running rough at 2800 rpm and faster. So I check the cable set ups, to make sure that the interrupt and overstroke swithches were set right. Still not any improvement. I then unplug the E.S.A. module without an improvement. I even went back to the old condensor and rotor still the same. I did a quick
check on the fuel pump, ( disconnected it from the carb and check flow as I cranked the motor) it looked good. So now I am thinking coil but I am unsure of how to check it. So would someone give me some input to how to check the coil and what ever else would be suspect causing the problem. By the way my tach is also not working, I am wondering if this could be common to the problems.
