I have a 1990 Glasstron 185 originally It had a 4.3L the prop that was on the boat was a 13 1/4 x 23p boat is about 2000lbs the gears that are in the outdrive are unknown Now the boat has a 350 with 350hp so I was told that I need to change the gears can I just change the prop I have a 14 1/4x26p will that work If not I don't know what gears are in the out drive now but I have seen 350s run 1.65-1 ,1.50-1 and 1.47-1 but what ones should I run I have a few different props that I can try starting with a 19p a 23p and the 26p I have a few others but can't recall what they are right now.
