Re: what exactly does a rectifier do...
mellowyellow is right on but I will elaborate some. The AC is generated by the rotating magnet in the rotor or crankshaft. Depending on the stators characteristics the voltage output can be anything, some times the voltage is tapped off and taken to the tach as AC as the tach may count the pulses or an average current will be generated and used for needle movement. Thats why some tachs have a switch to select the number of poles. The recitfier (Single Diode, Half bridge, Full bridge) allows current to flow in one direction. Thus you end up pulsating DC. Batteries act as capacitors and typicaly filter most of the pulses out, or there may be some filtering in the requlator. This current is then used to charge the battery. It can get deeper than this. Just though I would throw in a little more detail.<br /><br />Singshot
