chrysler1977
- Mar 6, 2012
- 3
First, what does a coil do?
Second, are mine bad? My two coils alternate between each other in getting very hot as I turn the key (note, the boat doesnt start yet... I think i need a new solenoid because it doesnt work unless I bypass it by using two screwdrivers to make the connection)...ive discovered while I am turning the key just to "see what happens," one of the coils will get super hot. And then the next day, the other coil may be the one getting hot while I do this. a picture of similar coils can be found at: http://www.chrysleroutboards.com/chrysler_outboard_parts_and_serv.htm look at the one about half way down that says Size comparison of 12V coils F380475 & F2A91475.
do you know if these coils are supposed to get hot/stay cold/alternate? and also, I am not sure what exactly the coils do?
45hp chrysler 1978 model 457H8J if that helps....
thanks!
thanks!
