What else would 14", 15 spline props fit that came from 225 Suzuki? I don't need em
toddschubert
I have acquired 3 props from my dads suzuki outboard (18,20,22 pitch) and am trying to sell them. 14 1/4 diameter stainless steel . Does anyone know if they will fit any other motors or just zuki. I'm a johnson guy and have no need for them.
Thanks for any input.
toddschubert
My Johnson runs just fine with the prop it has but I have acquired 3 props from my dads suzuki outboard (18,20,22 pitch) and am trying to sell them. 14 " diameter stainless steel . Does anyone know if they will fit any other motors or just zuki. I'm a johnson guy and have no need for them.
deejaycee_2000
Re: Zuki props question will they fit any other motors
Yes they will fit other motors .... just advertise them by stating how many splines etc....
Chris1956
Re: What else would 14", 15 spline props fit that came from 225 Suzuki? I don't need
You might post this in the Prop forum. You could look up modular props for suzuki and see what other motors they fit. That will give a clue.
schematic
honda 135hp - 225hp
boobie
Post them on E-Bay.
jestor68
If you visit the prop section and look up a Susuki prop made by Mercury; you'll see a certain hub number listed, which is different from the others.
If you visit the Susuki web site; prop section, prop bushing application chart; it lists all the bushings as "press in" type. That tells me that all the Susuki props use pressed in bushings.
If you look up a Solas Amita(pressed in hub) 14.5 X 19 prop, you see different numbers listed for all of them except Merc and Honda(match). Under Solas Rubex, they all list a different hub number. :confused:
Beats the heck out of me. Try it on a different motor and see if it fits. But it appears that Susuki props may only fit Susuki.
If you list it on E Bay as fitting whatever, and it doesn't, you'll likely get burned with a negative feed back. :mad:
JoLin
Agree with Jestor. Unless you can guarantee that the Suzuki 15 spline prop'll fit a Honda or whatever 15 spline motor, I wouldn't want to bet my money on it. If my motor also uses a 15 spline prop, does that mean that my motor's prop shaft is the same diameter and same length as Suzuki's?
My .02
