What else could it be?
Jonlando
I have an E10selcns that I recently acquired. The throttle gear was out of alignment to the timing when I received and I have also done the link and sync. I have two different carburetors that have been soaked in cleaner, lead plugs pulled, blown through with compressed air and rebuilt with new parts and properly adjusted floats. It starts and runs fine from low rpm to high rpm without issue. However, when you let go of the throttle it will just die out when the throttle play closes. It will not idle and the adjustment screw has no effect on how the motor runs with either carb installed. Have put on 2 new fuel pumps, fuel lines and new spark plugs to rule those out as well. I’m new to outboards, not mechanics though, and not sure where else to go...
oldboat1
Were the lead plugs reinstalled? They are part of the mfg process, and meant to be in place.
movement may result from ignition sensor or charge coil being installed to close to the flywheel — need to be perfectly flush with the machined edges of mounting posts.
no change when adjusting idle mix needle would be a clue that the carb idle passages have not been cleared.
Jonlando
Hello, yes new plugs were installed. The carbs were near spotless when I opened them to begin with. However, they are clear and I could blow brake cleaner cleanly through passages.
