What does the Throttle Friction knob do?
0xB33F
Sorry if this doesn't belong in this section. I wasn't sure where to post this.
Anyway - On my 1971 Johnson control thing, there is a "throttle friction" knob. I can turn it, but have no idea what it's doing.
Could someone give me some pointers?
Thanks in advance.
redone4x4
Re: What does the Throttle Friction knob do?
I believe it sets the tension on the throttle, so you can "cruise" at a particular speed.
0xB33F
Could you explain a little more?
I'm sorry. I'm totally new to boating, so I'm pretty dumb when it comes to this stuff ;)
redone4x4
is this an outboard? is it a console control (steering wheel and a dashboard)? what kind of boat is it?
0xB33F
It's a 1971 Johnson 50hp outboard. The boat is a 1971 (or 1973, not sure) Yarcraft Yankee 15'.
She's got a few quirks, but she runs.
redone4x4
so do you steer it at the outboard then, with the throttle/tiller handle?
0xB33F
Nope, she has a steering wheel.
The knob in question in under the white horizontal lever.
0xB33F
btw - thanks for all your help redone4x4. I appreciate it.
smartwork
Sounds like an adjustment to vary the amount of pressure/tension is placed on the throttle lever so that you can make it easier to move (if you move it a lot while driving) or make it stiffer (so it will keep it's position) if you drive in a manner where you don't move the lever much. Do you feel any difference in the lever movement with the knob set to different positions?
0xB33F
Thanks for the reply smartwork.
I can't really tell a difference. Maybe I'm just not paying enough attention?!
I'll have to mess with it a bit and see if I can tell a difference.
redone4x4
ya when running at say, 1/2 throttle, try to increase the friction and see if the lever stays at 1/2 throttle. it should. or, you back off the tension and it might start slowly losing rpm's.
RICHARD5
It stops down the prop for those high RPM, low speed situations. :D
Seriously, it's a friction lock to hold the throttle at a specific setting. Without the increased friction the throttle could vibrate to a lower RPM setting. It works by applying enough force to counteract the cable tension. The required amount of force is determined by the operator. In boats it's pretty much a convenience, in aircraft it's often a necessity.
Silvertip
Throttle friction is exactly what it means. Tighten the knob and it increases the amount of force it takes to move the throttle. Loosen it too far and the throttle won't stay where you have it set -- in other words it will creep back toward slow/neutral. Tighten it too tight and the throttle will be difficult to move. Happiness is somewhere in between.
