what does the control valve assym do???????????
jeremy5780
I have a 1990 200 johnson vro and i noticed the control valve assym #0394407 dripping water. I was just curious what does this part do? I noticed since it developed this drip my motor pees ALOT stronger!!!!
wmconway
Re: what does the control valve assym do???????????
control valve regulates flow for higher RPM. That's why it's tied to the throttle. Look up the posts by dhadley. I think it was "control valve ?"
Faztbullet
It controls the water flow from t-stats/poppets(the stat is also a poppet) With it leaking the t-stats are unseating and allowing more water to flow thru block.
jeremy5780
Thanks I plan on replacing the seal and wiper this weekend just curious as to what it did thanks again
